Message |
Hi So, apparently, when I purchased the car it had NA injectors in it, lol, no wonder it never ran right. I just replaced my fuel injectors with Nismo 740cc. While I was at it, I did the throttle body coolant bypass, replaced coolant hoses and will be replacing all my fuel injection hoses. Anyway, I just wanted to make sure my fuel rail wasn't leaking after installing the new injectors, so I hooked everything up like this before I reinstall the rail and plenum. Nothing appears to be leaking :-) :-) :-) When I turn the car on, the fuel pressure does not rise until I get out and spin the CAS, then it rises to ~43 psi while I'm spinning it, but when I stop spinning, it drops to around 18 psi and holds there. Is this normal behavior? Anything else I should do or check before I put it back together? Thank you for your expert advise.
